300k Miles Club
  • 300k Miles Club
    300K and up. List your mods, list your secrets or list your maintenance routines.
    2007.5 Silverado LTZ, LMM, 307K mostly highway miles. About 50k miles ago shortly after purchasing it, I put on Stainless 4" exhaust, EGR Delete, CAT filter and one of Idaho Rob's DSP5 tunes up to 90hp. Very Happy with the truck. Using it for work all over the country.
      Glad to hear its treating you well. Do you have a lift pump? What oil are you running, and how often do you change it?
        308k 2005 cclb srw 4x4. Efi live by Idaho rob , s&b mouth peice, cat filter, ppe lift pump, 19.5 wheels and tires, and a stage 5 ppe transmission with a precision ml converter that I just completed last weekend. I run semi sythetic rotella changed every 5k , (I tweaked my tuning to remind me)
          I run Shell Rotella full synthetic, I change it according to the oil life monitor which I think last change had around 9000 miles on it and oil still looks, feels, and smells good. I always plug in the block heater on a timer in the winter and that really helps to extend oil life. No lift pump...yet. I don't run it hard, and I figured if it made it this long without one.......soon though, still not sure which one to get. Getting ready to leave for another trip across the country at end of month and hoping to get the Allison switched over from Dex6 to Transynd before leaving. Still no tracking info on the DMax store order though. (ID 45936)
            Thank you for the post. I am going to have the shipping department get this figured out ASAP.
              I just wanted to say thanks for looking into my order and taking care of your customer, I appreciate it.
                Thank you for your patience.
                  2004 LB7 hit the 300k mark today. It had the first set of injectors at 198k. Second set of injectors just done recently at 295k with S&S SAC00. Other than that it has an Airdog II-4G 100 and use Opti-Lube Summer Blend or XPD. Here's to another 300k!
