I recently switched my 2008 Duramax Allison to Transynd after reading many rave reviews. Previously I was using non-synthetic. Perhaps it is just coincidence but after a few hundred miles my Allison started slipping and seeming to be getting worse. Sometimes on cold start-ups, but mostly on really hot days, load or no load, it slips for a while, then takes hold, then may slip again after a while. both tow mode and drive. Is there any reason to think going to synthetic triggered this and should I : a. go back to dino oil. b. change to different fluid. c. change transynd again. Truck is 2008 Crew cab LTZ dually with 240k on it.
Allison slipping since fluid change
Originally posted by Heavy MetalHI Mike! I just drained from plug. Filled to hot full with engine running. I had it checked this weekend and there were no codes. Should first step be a dropped pan change and another new filter?
Originally posted by Heavy MetalYes, truck is bone stock. Did not measure exactly. Bot the Transynd kit , started at about 7 quarts and and topped it off.
Curious if you have checked the Tcase fluid and condition?
Did you figure out your problem? I have a 2005 lly and I just did a fluid change with external filter only. Used the transynd and now after service it won't go into R hot or cold. It does however go in if I shift it though the gears for 10 min. Any help would be appreciated
Sent from my SM-G935V using Tapatalk
Originally posted by AndremaxproblemsDid you figure out your problem? I have a 2005 lly and I just did a fluid change with external filter only. Used the transynd and now after service it won't go into R hot or cold. It does however go in if I shift it though the gears for 10 min. Any help would be appreciated
