2021 Chevrolet Suburban and Tahoe
  • 2021 Chevrolet Suburban and Tahoe
    GM has introduced the all new 2021 Chevy suburban and Tahoe, they have been completely redesigned on the interior and exterior. They offer more powertrains to include the all new 3.0 L Duramax Diesel mated to the standard 10 speed automatic transmission. They have introduced new trim levels to align with the Silverado 1500 trims. The iconic Tahoe and Suburban are now class leading with the all new redesign.
    2021 Tahoe RST
    2021 Tahoe Z71
    2021 Suburban High Country
    With an all new independent front and rear suspension design they have improved the driving dynamics as well as increase rear leg room by up to 10". The all new Chevy Suburban and Tahoe have class leading technologies to optimize performance and efficiency. The Tahoe and Suburban both feature independent rear suspension, available magnetic ride control, and adjustable air ride suspension to have the best all around driving dynamics in its segment.
ID:	5422 Click image for larger version
    Specs:
    2020 Tahoe 2021 Tahoe Change
    Wheelbase (inches) 116 120.9
    Overall Length (inches) 204 210.7
    Legroom – Second Row (inches) 39 42
    Legroom – Third Row (inches) 24.8 34.9
    Cargo Room Behind Third Row (cubic feet) 15.3 25.5
    Max Cargo Room (cubic feet) 94.7 122.9
    2020 Suburban 2021 Suburban Change Change
    Wheelbase (inches) 130 134.1 4.1
    Overall Length (inches) 224.4 225.7 1.3
    Legroom – Second Row (inches) 39.7 42 2.3
    Legroom – Third Row (inches) 34.5 36.7 2.2
    Cargo Room Behind Third Row (cubic feet) 39.3 41.1 1.8
    Max Cargo Room (cubic feet) 121.7 144.7 23
    TRANSMISSION & AXLE
    Type: Hydra-Matic 10L80 10-speed automatic
    Final Drive Ratio: 3.23 (with all engines)
    CHASSIS & SUSPENSION
    Front Suspension: Independent coil-over-shocks and stabilizer bar; available Air Ride Adaptive Suspension and Magnetic Ride Control
    Rear Suspension: Independent multilink with coil-over shocks and stabilizer bar; available Air Ride Adaptive Suspension and Magnetic Ride Control
    Steering Type: Electric power-assisted rack-and-pinion
    Brake Type: Four-wheel disc with ABS; vented front and rear DuralifeTM rotors
    Wheel Size: 18-in aluminum (standard)
    20-in aluminum (available)
    22-in aluminum (available)
    Tires: P265/65R18 all-season
    P275/60R20 all-season or all-terrain
    P275/50R22 all-season
    EXTERIOR DIMENSIONS
    TAHOE SUBURBAN
    Wheelbase
    (in / mm):
    120.9 / 3071 134.1 / 3407
    Overall Length
    (in / mm):
    210.7 / 5351 225.7 / 5732
    Overall Width
    (in / mm):
    81.0 / 2058 81.1 / 2059
    Overall Height
    (in / mm):
    75.9 / 1927 75.7 / 1923
    Track (in / mm): 68.5 / 1741 (front)
    68.3 / 1734 (rear)
    68.5 / 1741 (front)
    68.3 / 1734 (rear)
    INTERIOR DIMENSIONS
    TAHOE SUBURBAN
    Headroom
    (in / mm):
    42.3 / 1074 (first row)
    38.9 / 988 (second row)
    38.2 / 970 (third row)
    38.8 / 988 (second row)
    Legroom
    (in / mm):
    44.5 / 1131 (first row)
    42 / 1068 (second row)
    34.9 / 886 (third row)
    36.7 / 933 (third row)
    EPA Passenger Volume
    (cu ft / L):
    168.4 / 4768 170.4 / 4826
    Cargo Volume^
    (cu ft / L):
    122.9 / 3479 (behind first row)
    72.7 / 2058 (behind second row)
    25.5 / 722 (behind third row)
    144.7 / 4097 (behind first row)
    92.9 / 2632 (behind second row)
    41.1 / 1164 (behind third row)
