Dmax Exhaust Choices
  • Dmax Exhaust Choices
    Post up what you are running for exhaust and how does it sound and work for you, so our members can get an idea of what will work for their particular taste!
    mine
    04.5 LLY Magnaflow XL Muffler, 3" MBRP Down Pipe dumped before the rear axle. For me this set up sounds semi stock at idle and under normal throttle positions. But once you go WOT she sounds really good. Not too loud at all and no drone in the cab!
      Mine is a 4" straight pipe, coming off a 3" SDP dp, dumped over the axle. Cruising speeds is nice not to loud at all, but once in the skinny pedal it will wake you up.
        All stock in this area. Can't beat it for quietness and zero drone
          Mbrp has always been good to me. Had a cat back 5 inch dumped and now I have a mbrp 4 inch cat back. Both fit good but hate the supplies clamps
            MBRP 4in down pipe 5in out the back with a 7in tip/ as a single had a great growl to it. As a twin it has a deep roar to it. As a single it did spool quicker with the stock 3.5 down pipe back, I like the bigger now with the twins and fuel I'm running twin cp3 and 120 over apex 6 with body mods Click image for larger version
              Originally posted by DirtyMax63 View Post
              MBRP 4in down pipe 5in out the back with a 7in tip/ as a single had a great growl to it. As a twin it has a deep roar to it. As a single it did spool quicker with the stock 3.5 down pipe back, I like the bigger now with the twins and fuel I'm running twin cp3 and 120 over apex 6 with body mods [ATTACH=CONFIG]n404[/ATTACH]
              Nice set up!
                Thanks, it is fun to run
                  It looks sweet man, great setup
                    nice set up boys!!
                      5" Magnaflow straight pipe exiting in stock location, 3" Magnaflow downpipe and all for cheap. Sounds like a jet plane of pleasure! Fitment is real good except that is very close to the transmission lines...
                        what year is your truck?
                          Its a 2006 LBZ, crew cab long bed with all the bells and whistles. Only 65,000 miles as well. To go along with the exhaust I just have a edge evolution crap tuner.
                            I posted instead of quoting, sorry it's midnight here in Virginia!
                              Diamond 4 inch catback.
