So being a LB7 owner I am a bit OCD about clean fuel. Got the Dmax Store to do a brand new set of injectors when I got the truck (3-4 yrs ago and about 80k miles ago now). That being said last summer couple started to go south so had the entire drivers side bank replaced. When I bought the truck and had the injectors done also put on a ADII 165 and a nictane adapter with a CAT 1R-0750 filter. Change all filters (AD and cat filter) with every oil change. Love my truck but injectors are driving me crazy. That being said was doing a ton of reading online about fuel filtration.
I was running Fleetguard filters (FF5613/FS19768) on mine, but after doing a ton of reading and research online, changed over to a Baldwin BF1275 for the water separator, and Donaldson P5513135 for the filter side. Then Running a CAT 1R-0750 (with nicktane adapter) in place of the OEM filter.
On the water separator..
Fleetguard/AD is rated at 50% freewater and 0% emulsified (not very good)
Baldwin is rated at 99% freewater and 96.5% emulsified water.
Fine particle filter is...
Fleetguard 5um absolute single pass @ 59.95GPH
Donaldson 3um absolute single pass @ 90GPH
**As a side note the CAT 1R-0750 & 1R-0749 are rated at 2 micron nominal. There absolute rating is 4 micron. Still about twice as good as the OEM Racor.
Since Im running a CAT 1R-0750 in place of the OEM filter there is no water separator, so running the Fleetguard I pretty much wasn't getting much protection from water, the Baldwin separator in my opinion is a must if you arent running a secondary water separator. I think its actually cheaper than the Fleetguard/AD filter as well...
Leaves me wondering if some of my injector issues were self inflicted due to some water getting to the injectors, time will tell....
On a side note I run Optilube in every tank and have since I got the truck, and fill up at busy stations (generally all Chevron).
Thoughts, comments or questions? What are yall running for filtration, opinions on what I mentioned above?
