So lets hear it guys. What lift pumps are you running and how do you like it?
Lift pumps
I will be getting an airdog 4g soon. Been thinking of a fuel filter delete bowl also. I know alot of people go back and forth about what lift pump is best for them so I thought a thread about what people are running would help them decide.
What made me pick the 4g was mounting location and how quiet that say it is.07 LBZ Built Transmission by Inglewood Transmission
I like the filter selection for the fass. The mounting is a like and don't like for me..... I like it because it looks like it would be easier changing filters at that location but I don't like it because it's next to the tire and looks like it can be damaged easer.07 LBZ Built Transmission by Inglewood Transmission
- 1 like
That is a great point reading the FASS system. I pulled the trigger and installed the Fass 95 on my 03 HD2500. I used the adjustable bracket to mount it forward and upward a bit. Then put the black flexible plastic wire conduit on all the hoses. It has been great and the truck runs so sweet sucking up that pure fuel.
Originally posted by Dukcaln@DmaxstoreI for one, love the FASS, and am running the Fass Fuel filter delete as well. I do however, get the below 1/4 hard start every so often. I plan on eliminating that with a bean sump. Very soon! Will do a right up and review on it as far as install and results.07 LBZ Built Transmission by Inglewood Transmission
All Dmax trucks need a lift pump. I run a Fass 150 and love everything about, not noisy never run out of fuel and yes do a sump because the 1/4 tank run out thing sucks. Maybe make the draw straw longer, who knows. Definitely make more HP even if your just a stock motor. Cold air and lift pump should be the first upgrade on the Dmax.
