Hi There,
My name is Courtney and I'm new to the forum but I've got a puzzler that I've been trying to diagnose / fix and I was hoping someone with more experience could help me out.
Hopefully this may also help someone else out in the future
Thanks in advance!
Truck:
2003 Chevy 2500HD w/ LB7
Allison
270k
Mods:
EFI Live Max Effort tune
New Bosch Injectors installed this year
New Fleece CP3k installed this year ( it’s a modded LBZ CP3 pump w/ reg remapped by tune )
AirDog 165 4g lift pump cracked up to about 15 PSI at idle
PPE fuel rail race valve / plug
PPE boost increase valve
AirHorn
S&B Intake
CAT 2 micron fuel filter ( ~4 months old )
Problem:
On stock or tow tune the tuck will hold rail pressure at wide open throttle no problem…
When commanded 23k the actual is right there at 23k
But on large tune (+230 HP Max Effort) at WOT the rail pressure drops to between 14k and 16k depending on RPM.
Diagnostics / troubleshooting:
I’ve recently replaced the fuel filters at the lift pump and filter head.
I’ve verified low side fuel pressure @ idle to be 15PSI w/ gauge at port near alternator.
I’ve dropped the tank to check for debris / obstructions and cleaned it ( nothing there it was clean to begin with )
I don’t have any leaks
The filter head is new and primer button is always firm so I don’t suspect any leaks
Visual inspection of all the hoses and I don’t see any kinks / obstructions.
Injector balance rates are all in spec
Checked engine oil and it is clean (no diesel in oil)
Tested return rate on injectors + CP3 w/ 15 second crank test (https://www.youtube.com/watch?v=t9Da8rcL1jA) and it came back at 70ml ( <100ml is normal )
Interesting findings…
When preforming the return rate test I noticed that when I turned the key to the accessory mode which engages the lift pump I’d get a slow stream of fuel coming out of the return line to the tank. My guess is that the PPE fuel rail race valve is the reason. The stock fuel rail pressure relief valve has a spring tensioner which keeps the valve closed under normal operating conditions but pops open when rail pressure spikes to avoid damage. The PPE valve is actually just a slug with a hole machined in it and therefore always bleeds off a little fuel to prevent damage. Is this correct, it seems logical but I haven’t worked on enough LB7’s w/ race plugs to be certain?
One theory I have is that with the injector duration at the highest tune combined with the constant bleed from the PPE valve that the Fleece CP3k can’t keep up. I could test this by reverting back to the original factory FPRV.
A second theory I have is perhaps to increase rail pressure I could have a custom tune made up which commands more then 23k PSI, my understanding is that the LBZ CP3’s handle between 26k to 29k so it could be that a tune could just ask the pump for more.
Another theory I have is that while return rate is within spec I have just enough return from one of the injectors or CP3 that it just won’t hold rail pressure on the big tunes.
I hope it’s not an injector or a CP3 as I’ve just replaced both within the last year and neither my back or my wallet are looking forward to doing either any time soon
For fun and a little extra info I’ve attached a screen shot of a trace I took while getting on the highway where I put a foot on it and drained the rail pressure.
Thanks in advance!
Truck:
Allison
270k
Mods:
AirHorn
S&B Intake
Problem:
