If this is your first visit, be sure to check out the FAQ by clicking the link above. You must login or register before you can post: click here to register. To start viewing messages, select the forum that you want to visit from the selection below.
This will not void your warranty. It may not be smog legal in your area. The benefit of not having oil vapor go back into your intake and inter cooler is major.
I think that the 2015 Dmax has an oil separator in the PCV system that drains the oil back to the pan on the drivers side front cover near the bottom. I'll have to double check .
I know this is an old thread. I have the Pcv reroute hose and “T” fitting to drain over board. My lml has the pan drain. I am thinking it may be a good idea to add another “T” to include the pan drain line. To keep pressure from building in the pan. So that valve covers and pan all have ambient pressure. May be a waste but since it’s there
If this is your same project you can keep the original system but where the vapor pipe would go to the turbo inlet you could run it to atmosphere. I haven't done much research on this system. I have tested the stock LBZ and LMM pcv system and have found that there is quite a bit of vacuum on the crank case in stock form. I will have to test a LML in the near future. Hope this is helpful.
Sent from my SAMSUNG-SM-G891A using Tapatalk
