The DMAX STORE is proud to offer our customers a Extreme Duty Line for their Duramax with a great warranty tot he original purchaser!
(Dmax XD Warranty)Dmaxstore XD Steering and suspension parts come with a no questions asked 3 year unlimited milage warranty to the original purchaser. Warranty period begins at date of purchase. If a failure occurs, Dmaxstore will replace the failed part only once it has been recieved at our facility. Shipping costs are not included under the warranty.
Lets get started!
If your looking for a quality wheel bearing at a great price Dmaxstore has you covered. The (Xtreme Duty) XD is a Dmaxstore exclusive. Imported from Canada using the highest quality components available. Each part comes with 8 new wheel studs and ABS brake line. These are complete bolt in units and fit both right and left spindles. Average install time is around 2 hours.
Priced at $139.99
Buy here!
https://dmaxstore.com/products/?route...product_id=912
Fitment:
2001-2010 (GMC/Chevrolet) 2500-3500 HD Single Rear Wheel.
2002-2007 (Hummer H2)
Torque Specs:
Axle Nut-177 lb.ft
Spindle Bolts-133 lb.ft
Main Caliper Bolts-221 lb.ft
The XD upper control arms are a direct replacement for your 2001 to 2010 GMC Sierra or Chevrolet Silverado 2500 / 3500 HD truck. Imported from Canada using the highest quality materials available. They are backed with a 3 year no question replacement warranty.
Priced at $199.99 for the Pair
Buy Here!
https://dmaxstore.com/products/?route...=911&search=xd
DMAX XD Tie Rods
Priced at $229.99 These are a great purchase for that extra stability. These will hold up to boosted launches, High HP applications and Lifted Vehicles. From Stock to Wild, these will work!
Buy Here
https://dmaxstore.com/products/?route...=776&search=xd
Sold as a complete set (Inner / Outer / Left / Right)
We are proud to introduce our new XD heavy-duty tie rod assemblies for GM trucks, 3/4 ton Suburban, and Hummer H2. Our popular tie rod assemblies are now better than ever.
The outer tie rod end has been redesigned to eliminate the weak (buckling) point that the original design is known for.
An oversized 1 1/2" solid forging has replaced the original undersized 1/2" rod where the buckling occurs. The outer
end also has a larger diameter full ball stud and socket allowing for a larger grease able wear surface, and increasing
reliability. This larger socket and ball also offers more stud swing for greater articulation. The Inner Tie Rod end incorporates
the same oversize design with a ¾” threaded rod replacing the original ½” rod. The inner ball and socket has
also been increased from 25mm to 32mm. Pre-greased with (AMSOIL) synthetic lubricant. Made in the USA.
Dmaxstore Note:
If vehicle has been lifted tie rods may need to be altered to the lift kit manufacturers specifications.
Replacement Dmaxstore XD Outer tie rod.
Can also be used as an upgraded outer tie rod for original Rare parts xtreme duty or G2 tie rods.
Note-(sold individually-will work for left or right replacement or upgrade)
Replacement right hand thread inner tie rod for DMAXSTORE XD and All Rare Parts series tie rods. Compare to Rare Parts G2.
Kit Includes:
DMAX XD - Xtreme duty tie rod kit. Joints have the same protection as the factory joints, but are almost twice the size! No more bending the adjuster shaft either, this unit has more than twice the cross sectional area than the factory adjuster. Will work on stock/lifted/ or lowered trucks using OEM tie rods.
(Cognito) Pitman/Idler Arm Support Kit
If you running any tire bigger than a stock this is a must have kit. Designed specifically for Duramax owners
Kit Includes:
2 x DMAX-XD Xtreme Duty Tie Rods
1 x Cognito Pitman Idler Support Kit
DMAX / XD - Xtreme duty tie rod kit. Joints have the same protection as the factory joints, but are almost twice the size! No more bending the adjuster shaft either, this unit has more than twice the cross sectional area than the factory adjuster. Will work on stock/lifted/ or lowered trucks using OEM tie rods.
Priced at $39.99 these XD Press in Upper Ball Joints are a great buy
https://dmaxstore.com/products/?route...1098&search=xd
Dmax XD Press In Upper Ball Joint
Fits 2001-2010 Chevy/GMC 2500/3500 HD
1-Upper ball joint Part# DMAXXD6696
Details:
Priced at $39.99 these XD Bolt in Ball Joints are a great buy
https://dmaxstore.com/products/?route...=890&search=xd
Dmax XD Bolt In Upper Ball Joints
Fits 2001-current Chevy/GMC 2500/3500 HD
This Dmax XD ball joint will fit Cognito upper control arm kits (Part#'s UCAK100001, UCAK100010, UCAK100051), Kryptonite upper control arm kits (Part#'s KRY-UCAK-0110, KRY-UCAK-1151), should also work with fabtech tubular upper control arms with a bolt in upper ball joint.
Priced at $49.99 these XD Press in Lower Ball Joints are a great buy
https://dmaxstore.com/products/?route...1099&search=xd
Dmax XD Press In Lower Ball Joint
1-Upper ball joint Part# DMAXXD6693
Details:
Lets get started!
DMAXSTORE XD (Xtreme Duty) Wheel Bearing
Fits 2001-2010 Chevy/GMC 2500 / 3500 Single Rear Wheel
Part# XD310/XD312
Priced at $139.99
Buy here!
Fitment:
Torque Specs:
Axle Nut-177 lb.ft
Dmaxstore XD (Xtreme Duty) Upper Control Arms
Fitment 2001-2010 Duramax Duramax Diesel 2500hd and 3500hd
Buy Here!
- 2 Complete XD Upper Control Arms
- New Bushings
- New Ball Joints
- Pre Assembled And Ready To Install
DMAX XD Tie Rods
Fits Chevy/GMC 2500/3500HD & H2 Hummer
Buy Here
- Upgraded 1.5" forgings
- Full ball studs
- Steel-on-steel internal design
- Increased stud swing
- Sealed boot
- Assembled in the USA
Dmaxstore Note:
DMAXSTORE XD Outer Tie Rod
DMAXSTORE XD Inner Tie Rod
GM/Chevrolet 2500/3500 HD Trucks
Dmax XD Tie Rods+Cognito PISK Kit Package
Fits 2001-2010 Chevy GMC 2500/3500HD
Kit Includes:
- 2 x DMAX XD Xtreme Duty Tie Rods
- 1 x Cognito Pitman Idler Support Kit
- Includes hardware for factory or after market pitman and idler arms
- Supports your Pitman and Idler Arms from Stress and Wear
- Comes Complete with All Parts for Installation
DMAX XD Tie Rods + Cognito PISK
Fits 2011-Current Chevy/GMC 2500/3500HD
Part# DMAX-XDLML+PISK3008
Kit Includes:
Details:
- Designed to replace the factory ball joints that are prone to premature wear on lifted vehicles with large off-road tires
- Fully greasable metal on metal design
- Machined bearing housing made from sintered graphite, bronze, and 1045 steel for a strong, smooth, bearing surface
- Ball joint stud made from PPM-4140 steel with an induction heat treated bearing surface for smooth operation and maximum life
- Ball joint boot is made from tear/wear resistant silicone polyurethane
- Outperforms the factory ball joint assembly and includes all necessary hardware for installation
- 1 Dmax xd Upper ball joint
Details:
