DMAXSTORE Service Facility Steering & Suspension Activity
  • DMAXSTORE Service Facility Steering & Suspension Activity
    Updates from the DMAXSTORE Service Facility, All things Steering and Suspension
    2015 With BDS Lift at 5.5" ride Height with 35's on Stock Wheel
    putting a hitch on this beaut of a truck
    getting some drilling done
      Very nice setup, smooth install and when removed you it you get full bed use
        I run a superglide or pullrite hitch and they are sweet to tow with. Nice when your done and everything is out and you can use your bed.
          cognito lift for this truck
          look at the ole white kryptonite UCA's and Kryptonite boxed lowers!!
            A customers 2015 getting some cognito love via lift with fox shocks
            before, leveled with t-bars adjusted!
            the bad cvc angles you get with t-bar adjustment, why we do not recommend it for any Duramax, more so the newer trucks as there is a 3" natural rake from the front to rear, so adjusting the front t-bars can create some nasty angles that will destroy the front end and cause shock breakage.
              and
                now the final look with the cognito 4-6" lift adjusted to the 5" mark- customer will be getting wheels and tires later.. but you can see, looks very similar to the original pic with the t-bars cranked excessively up to achieve the leveled look and eliminate the natural 3" rake
                Before, t-bars cranked
                very bad
                The after, done right with a lift
                and that is how you do it.. lifted, best ride comfort, no premature wear on front end or shock breakage and no nasty angles
                  Here is a recent 2015 we did with an RCD Lift, 35" tires and 16+ off set. Truck looks amazing and rides spectacular. Very minimal trimming was done on the front plastic valance, I mean very little. This is adjusted at the 6" ride height.
                    This bad boy is going to get a few nice upgrades
                      Love reading the updates Jason
                        Thanks, gets busy and hard to keep updated with stuff that isnt repetitive type of post.. This truck is big and sexy!!
                          Well keep up the good work Jason!
                            Have this 15 in for a cognito lift and some other goodies
                            Stuff just fell off, Lol!
                            Picture of a customers paint work on his suspension
                              Here is the 15 dually pictured above, 4" cognito instead of a leaving kit... As some know, the leaving kits won't level the LML's and when you crank the T-Bars to get that extra inch you really start to suffer with poor ride quality, premature wear on front components and broken shocks can sometimes happen. This is the best way to achieve the leveled look and great ride quality and keep the front end components happier.
