DMAXSTORE Service Facility Transmission, Transfer Case & Drivetrain Activity
little bit of motor mount replacement. Good idea to check on the mounts if your vehicle has high mileage or running more than stock TQ or HP.
of course engine vibration and TQ transfer to the transmission and T-Case can cause damage to the tranny mounts or a broken rear half of the trans. Luck for me I had the T-case brace but I did have some damage to the IC pipes and steering line... clearly from the boosted launches...
I can say my vibrations are completely gone and the freeway speed vibrations are so much smoother.. Why didnt I detect this earlier.
- 1 like
This beaut of a truck will be getting a DMAXSTORE Built Stage 5 transmission.
got it dropped and ready to build
going to turn out looking something like this, minus the pan as the customer has his own deep pan!!
also in addition to the transmission, this customer is doing some DDP Nozzles.
Dynomite Diesel 04.5-05 LLY 50hp NozzlesFits 2004.5-2005 Duramax 6.6 Chevy/GMC 2500/3500HDPart# DDP LLY50NZ1- Complete Set Of 8 Injector Nozzles
These DDP Precision injector nozzles will give you50hp at the rear wheels. They can be installed on any LLY injector. A nice upgrade to complement your performance Duramax using a stock or modified turbo.
Average fuel economy increases 1-2 MPG
Should be a really good running Dmax now!!! Built trans and DDP Injectors, Wow!
Two trucks, Two Dmaxstore Built Allisons!!
When we build and install a in house Dmaxstore built transmission we do a cooler flow test and back flush of the system at no charge for our customers. One for piece of mind and two to insure they have a proper working system to compliment their new Built Allison. This also protects their investment by assuring they have no underlying flow or debris issues.
Might be a little biassed, but darn these things are sexy!! And I have one in my LLY and they perform!
I don't think you can see too much of these epic red transmissions.
One stripped down and cleaned up, about ready for re-assembly.
Parts all cleaned up and waiting to get put back in.
Here is a completed Stage 5 ready to get put back in.
These are so clean you would think they were brand new.
