DMAXSTORE Service Facility Injector & fuel Systems
  • DMAXSTORE Service Facility Injector & fuel Systems
    Daily Fuel System updates
Name:	DDP LB7 injector set-500x500.jpg
    customer in with a LLY getting Arp studs, Grade C gaskets, Water Pump, Injection Pump and cleaning the nasty egr stuff up and more. When done with this it will go over to the lift for a dmaxstore built transmission
    studs in!!
    getting there!!
      had this customer with a in the bed auxiliary tank that needed some design changes to get the Air Dog to work properly
      added some shocks to the service
      and ended up with a new transfer case as the pump rub wasn't enough to destroy the inside
        another injector job for customer
          so a customers truck came in not running, a lb7 that was having some fuel pressure issues, zero to be exact! Here is what was found
          Total injection pump carnage!
          inside of the body plugs
          internal hub
          and the carnage that went through out the entire fuel system
            Another head stud, head gasket and so on
              those pesky lb7 injectors
                yet, another injector job and some tuning
                  Head gaskets and more
                      this LLY will be getting HG and the full treatment of goodies that goes along with it
                      take a look at the crude the egr leaves behind
                      couple hours later, down to the heads
                        so the LLY above got some fresh paint happening under the hood
                        Looking really good, when I have to do my LLY I am going to go all Black to match my HASP Pipes and Intake~~~ I think the red is killer!!
                          Installed this PPE dual fueler this week to assure there is proper supply when there is demand
                            Another look at this truck from out of state showing why it need the dual fueler
                              Another injector job done today!
